So im having a new issue this time with the end stops.
As soon as i do a homing the end stops get hit twice then the machines gets disconnected from the server.
I can see the LEDs flashing still on the board, And the motors sound like they are running. But after a couple of minutes it shuts down, the motors, but the LEDs stay on, and i can reconnect again.
I get this error in the terminal every time it happens.
Send: G91
Recv: ok
Send: G28 Z0
Unexpected error while reading serial port, please consult octoprint.log for details: SerialException: ‘read failed: [Errno 5] Input/output error’ @ comm.py:_readline:1618
Changing monitoring state from ‘Operational’ to ‘Offline: SerialException: ‘read failed: [Errno 5] Input/output error’ @ comm.py:_readline:1618’
Connection closed, closing down monitor
In my Redeem log files everything looks normal, too me at least.
The warning about a usb gadget serial does concern me, but to be honest im not sure what that even refers too.
2016-10-16 03:15:03,843 root INFO Found Replicape rev. 00B3
2016-10-16 03:15:04,090 root INFO Cooler connects therm E with fan 1
2016-10-16 03:15:04,096 root INFO Added fan 0 to M106/M107
2016-10-16 03:15:04,116 root INFO Added fan 3 to M106/M107
2016-10-16 03:15:04,593 root INFO Stepper watchdog started, timeout 500 s
2016-10-16 03:15:04,607 root WARNING USB gadget serial not available as /dev/ttyGS0
2016-10-16 03:15:04,611 root INFO Ethernet bound to port 50000
2016-10-16 03:15:04,778 root INFO Pipe octoprint open. Use ‘/dev/octoprint_1’ to communicate with it
2016-10-16 03:15:04,952 root INFO Pipe toggle open. Use ‘/dev/toggle_1’ to communicate with it
2016-10-16 03:15:05,113 root INFO Pipe testing open. Use ‘/dev/testing_1’ to communicate with it
2016-10-16 03:15:05,284 root INFO Pipe testing_noret open. Use ‘/dev/testing_noret_1’ to communicate with it
2016-10-16 03:15:05,308 root INFO Alarm: Operational
2016-10-16 03:15:05,316 root INFO Watchdog started, refresh 30 s
2016-10-16 03:15:05,320 root INFO Redeem ready
2016-10-16 03:20:18,784 root WARNING Heater time update large: H temp: 0.0 time delta: 0.253078937531
2016-10-16 03:20:18,779 root WARNING Heater time update large: E temp: 23.8441449244 time delta: 0.252753973007
2016-10-16 03:20:19,000 root WARNING Heater time update large: HBP temp: 22.0505634333 time delta: 0.503028154373
2016-10-16 03:21:50,676 root INFO End Stop Y1 hit!
2016-10-16 03:21:51,897 root INFO End Stop Z1 hit!
2016-10-16 03:21:53,473 root INFO End Stop X1 hit!
2016-10-16 03:22:04,134 root INFO End Stop Z1 hit!
2016-10-16 03:22:04,369 root INFO End Stop Y1 hit!
2016-10-16 03:22:04,456 root INFO End Stop X1 hit!
2016-10-16 03:20:42,584 root INFO – Logfile configured –
2016-10-16 03:20:43,180 root INFO Found Replicape rev. 00B3
2016-10-16 03:20:43,421 root INFO Cooler connects therm E with fan 1
2016-10-16 03:20:43,427 root INFO Added fan 0 to M106/M107
2016-10-16 03:20:43,443 root INFO Added fan 3 to M106/M107
2016-10-16 03:20:43,930 root INFO Stepper watchdog started, timeout 500 s
2016-10-16 03:20:43,935 root WARNING USB gadget serial not available as /dev/ttyGS0
2016-10-16 03:20:43,940 root INFO Ethernet bound to port 50000
2016-10-16 03:20:44,112 root INFO Pipe octoprint open. Use ‘/dev/octoprint_1’ to communicate with it
2016-10-16 03:20:44,288 root INFO Pipe toggle open. Use ‘/dev/toggle_1’ to communicate with it
2016-10-16 03:20:44,450 root INFO Pipe testing open. Use ‘/dev/testing_1’ to communicate with it
2016-10-16 03:20:44,612 root INFO Pipe testing_noret open. Use ‘/dev/testing_noret_1’ to communicate with it
2016-10-16 03:20:44,633 root INFO Alarm: Operational
2016-10-16 03:20:44,651 root INFO Watchdog started, refresh 30 s
2016-10-16 03:20:44,655 root INFO Redeem ready
