So I think I’ve butchered it at this point but I have a strip(1 data pin) of 71 led, I was tryingto set it up to do the Fire demo on 3 different segments. 22, 26, and 23. I’ve had partial pieces work. I think part of my issue is getting lost in the ‘heat’ portion.
@Matt12
In each of your function you have something like this
for( int k= 23 - 1; k >= 2; k–) {
heat[k] = (heat[k - 1] + heat[k - 2] + heat[k - 2] ) / 3;
Each time you are overriding all the leds from 2 to 23-1 in that example.
So the last function called will be displayed.
If you want each effect to affect only one part of the strip than you need to modify that.
@Yves_BAZIN I did try that a few times but maybe I had something wrong. I believe I was doing something like this for( int k= 48 - 1; k >= 23; k–)
@Matt12 indeed that sound better
Explain exactly what you want to do ?
you want to split the strip in 3 parts
from 0 to 22 for 22- 26 ??? and then 49 to 71 ??
Can you clarify this?
It will help me correct your code.
Yup, I am wanting 3 fires in one strip, 0-22(reversed), 23-46(normal), then 49 -71
Worked great except first strand, uncommented the thing you commented(the reverse direction code) and it’s perfect.
