So I decided to try to see how fast my printer can print....
So I decided to try to see how fast my printer can print… Base speed was 60mm/s and I topped out the multiplier to 999%. That’s basically 600mm/s!!! The only reason I can’t normally print at this speed is that the retraction isn’t fast enough. Don’t mind the bed adhesion… Still working on it
http://youtu.be/jcvNtJ-hMuI
Keep in mind that if you have firmware limits it wouldn’t be the full 999% faster.
There is no firmware limit and I do see what you mean with the acceleration. I just ran a 300mm/s print which was just 2 tall 180mm long walls and it was slower than the video. Still, that’s still some fast printing
Comparing position to video time while you’re at 999%, your printer is doing 1 loop around the box per second, maybe a little faster. How big is your box? Is that a 40mm square? Then you’re averaging about 160mm/s.
That does not look anywhere near 600mm/s. To make sure how fast you are reeeeeaaly going, print something 150x150mm then you’ll see if it goes under a second to print each side :wink:
