Smoothing ABS with XTC-3D...
gplus
(Zviad Sulaberidze) #1
Smoothing ABS with XTC-3D… and Voronoi style is so stunning! :smiley:
(Matteo Pascolini) #2
wow! how much stuff did you use?!? seems a little over done…
(Zviad Sulaberidze) #3
not much, but in some areas, it’s overdone, yes :slight_smile: did it first time :slight_smile:
(Zviad Sulaberidze) #4
actually, photos are bit overexposed, because they were too dark, and maybe it seems that they are overdone
(Brian Long) #5
How did you get get the holes in your model? What software do you use?
(Zviad Sulaberidze) #6
I took this model from Thingiverse. If you search for Voronoi, you will get a bunch of holed models :smiley: If you google “how to make Voronoi style”, I believe you get lot of info about it
(Kyle Weems) #7
One method, very easy… just make sure you have the latest version of meshmixer. http://www.protobuilds.com/#!How-to-Make-Voronoi-Patterns-with-Autodesk®-Meshmixer/c1r1n/554239780cf2adc1acfea766
