Hi,
I have a question, I’m trying to understand how readEncoderDelta() is implemented in ST7565.cpp
int ST7565::readEncoderDelta()
static int8_t enc_states[] = {0, -1, 1, 0, 1, 0, 0, -1, -1, 0, 0, 1, 0, 1, -1, 0};
static uint8_t old_AB = 0;
if(this->encoder_a_pin.connected()) {
// mviki
old_AB <<= 2; //remember previous state
old_AB |= ( this->encoder_a_pin.get() + ( this->encoder_b_pin.get() * 2 ) ); //add current state
return enc_states[(old_AB & 0x0f)];
} else {
return 0;
in the function old_AB is always initialized at every call to 0, how does the function remember the state of encA/B from the previous call to determine the direction of motion? the way it is the function will always evaluate (old_AB & 0x0f) to 0,1,2 or 3 based on the current state only
I’m also assuming this code is made to read a standard rotary encoder input, like this for example
thanks!
Sherif
