Hi,
My smoothieboard often stops regulating hot end temperature while printing.
A few minutes ago, during a print, my hot end started to produce white smoke (I am printing in ABS). I immediately checked temperature with a thermometer……270°C and rising….very strange…
I immediately sent a new setpoint with pronterface and temperature lowered. It 'seems like smoothie board has loosed it’s set point (or taken another one). but I don’t have any M104 or M109 codes in the middle of my file.
This inconvenience happens quite often (3 times in 6 prints). Pleas note that printing goes on properly (X-Y-Z-E). I did not check my heated plate due to panic.
This problem is quite serious, in my opinion. I don’t think this has something to do with probes hardware: when I send a new Gcode (M104 S225) temperature starts immediately to reduce and goes to right values. I enclose some readouts from my extruder, there are some strange oscillations (240 to 169 °C in few seconds ??)
SENT: M105
RECV: ok T:246.4 /225.0 @0 B:79.6 /80.0 @5
SENT: M105
RECV: ok T:244.5 /225.0 @0 B:79.6 /80.0 @188
SENT: M105
RECV: ok T:240.1 /225.0 @0 B:79.7 /80.0 @188
SENT: M105
RECV: ok T:207.6 /225.0 @64 B:79.6 /80.0 @189
SENT: M105
RECV: ok T:245.2 /225.0 @0 B:79.7 /80.0 @189
SENT: M105
RECV: ok T:201.9 /225.0 @64 B:79.7 /80.0 @189
SENT: M105
RECV: ok T:229.5 /225.0 @0 B:79.7 /80.0 @189
SENT: M105
RECV: ok T:198.8 /225.0 @0 B:79.7 /80.0 @189
SENT: M105
RECV: ok T:169.8 /225.0 @0 B:79.7 /80.0 @189
SENT: M105
RECV: ok T:206.0 /225.0 @64 B:79.7 /80.0 @190
SENT: M105
RECV: ok T:204.7 /225.0 @64 B:79.8 /80.0 @189
SENT: M105
RECV: ok T:241.2 /225.0 @0 B:79.8 /80.0 @189
SENT: M105
RECV: ok T:238.7 /225.0 @0 B:79.8 /80.0 @189
SENT: M105
RECV: ok T:233.3 /225.0 @0 B:79.9 /80.0 @189
SENT: M105
RECV: ok T:232.7 /225.0 @0 B:79.9 /80.0 @189
SENT: M105
RECV: ok T:231.5 /225.0 @0 B:79.9 /80.0 @189
SENT: M105
RECV: ok T:229.8 /225.0 @0 B:79.9 /80.0 @189
SENT: M105
RECV: ok T:227.8 /225.0 @0 B:79.9 /80.0 @189
SENT: M105
RECV: ok T:224.7 /225.0 @26 B:79.9 /80.0 @189
SENT: M105
RECV: ok T:221.5 /225.0 @64 B:79.9 /80.0 @189
SENT: M105
RECV: ok T:228.1 /225.0 @0 B:80.0 /80.0 @188
SENT: M105
RECV: ok T:227.0 /225.0 @0 B:80.0 /80.0 @188
SENT: M105
RECV: ok T:224.4 /225.0 @64 B:80.0 /80.0 @188
Any ideas ? Perhaps a PID runaway ?
Thanks
Imported from wikidot
