Smoothie V1.1 Power Input
I received a new Smoothie V1.1 and need to power it with an external 12.0v supply. The board came with the optional R-78E5.0 voltage regulator already installed. When I supply 12v to the VBB input nothing powers up.
The board powers up and communicates with my CNC Router software when powered from the USB socket.
What am I missing (other than “volts”)? :grin:
Bill
Hey there.
Are you sure you are getting the polarity correct? With some connector configurations, the connector labelling on the power input can get a bit confusing sometimes.
If even reversed, you get nothing, i would suspect the voltage regulator is dead and needs replacing.
What happens if you power the board via USB?
The board powers up and runs via USB. I sent the board to Chris and he says it is fine. It is extremely unlikely I had it wired backwards.
I am awaiting its return…
Beevo
