@Yuusuf_Sallahuddin_Y
That’s 200us (microseconds) and is the duration of a single pulse cycle.
The default number in most of the “off the shelf” Config files I’ve seen is 20us, 10X faster than this.
200us is much more reasonable, in my opinion.
To get pulse frequency you invert the number (divide 1 by it) which is 1/.0002 seconds= 5000 or 5khz (as Alex suggested) Remember thjis is cycles per second. To better understand how fast this is, 5000 x 60 = 300,000 pulses per minute. (note: at 20us this is 50khz)
My contention is this is rougher on the power supply and tube than is necessary. I would suggest that you reduce it until you see image degradation and them go back up 20 to 50%. That would cut down significantly on the tube starts which contribute to life reduction at least as much as ultimate current flow. You get the same net power control as at a higher frequency. I believe this frequency was “inherited” from a PWM program intended for electric motor control, and they don’t care how fast you switch them on and off (as much - they do see heating from the higher PWM freq due to magnetic inrush currents.
The lower limit on the PWM frequency is where ‘stitching’ starts to occur. At 200mm/sec and 5khz, you are seeing 25 operations per mm, or the head travels .04mm (40 microns) for each pulse. (at 20us this distance is .004mm or 4 microns)
I believe the best way to find out what frequency is best is to find it experimentally. Once determined for a specific it’s a linear function to adjust it to head speed. If 2500hz works best @ 250mm/ sec, then you can say to use 5000hz @ 500mm/sec or 1000hz @ 100mm/sec.
This would be a great project for you guys that have the engraving figured out quite scientifically to a high level, like Alex and Ariel, who did the level/darkness testing. You just may find another level of detail while testing. It’s doubtful 5khz is the best freq for all speeds and materials. I’m pretty sure there is room to improve things in these settings.
I wish I had time to do the testing, I really enjoy that sort of thing, but I have myself ‘fully entertained’ keeping the Upgrade kits and accessories moving thru.
As usual, I probably went deeper here than needed, but hope it helps you engravers. Someday, when things slow down a bit, I’m looking forward to doing some nice Merbau engravings. By then you guys can tell me exactly how to go about it.
Scott
PS when playing in the Config file don’t confuse the PWM pulse width with the trigger pulse width.This is the pulse that initiates the start of the PWM cycle and is very brief as to not ‘overlap’ into the next cycle at high frequencies. This parameter is not present on all Config files, but is usually 1us in the ones I’ve seen (this is just from memory)
