@Jarek_Szczepanski there should not be any influence on carriage linear movement with this 3 degree belt, since the angle doesnt change in all range of movements.
However I think that belt might try to slide off the bearing or belt will touch printed part that would prevent such slide. Having motor in half of the belt angle would probably solve it, but that might be not needed, tests will tell.
Machine I am building 400x340 build area, will have the angle much smaller.
