Showing off my Call Of Duty loading logo made for my autistic son all working ok but the light seems to stop in the middle my code is here
http://pastebin.com/embed/LS4UiupR
if someone could look and help as iam learning all this programming
https://youtu.be/RWlgmX_QRV8
how do i add photos as well
recount the number of leds in your array, I suspect that is off
@dave_windsor Your code says you have 32 pixels, and then, this…
for( i=0; i<36; i++) {
Also, where is the Fastled
@Stuart_Taylor you got me i had a computer fail big time and have lost everything except a few odd programs and sketches trying to get this working before xmas and thanks for pointing out the pixel count seems to be working now with this code only thing it i cant get it to light pixels twice with this code so it gives it a running effect continuasly around the array
Sorry @dave_windsor I dont know the adafruit library, but your code looks overy complex for a running light.
ok thanks Stuart Taylor ill try and get a fastled one which will do the same pc picked a good time to have melt down lol
Nice, that Treyarch knot logo looks cool
@Luminous_Elements thanks just having trouble finding a sketch which will do what i want as iam new to this the one iam suring works but not happy with it as i cant get it to do the same number twice to give the full running effect
@dave_windsor what effect are you after?
Just the same running light?
Also, the LEDs, they do they run in order? I.e 1234…32
@Stuart_Taylor hi yeah its in order and just a running light thats all my autistic son loves the cod loading logo and asked me to make him one so iam lol
https://www.zonerama.com/Link/Photo/40806048/1099408 their is a photo of numbering would love order to go
1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,9,23,24,25,26,27,28,29,30,31,11,32,21
but dont know if this is possable any help would be greeat
@Stuart_Taylor thanks i have a error it says this has loads but this is what says on last bit
no matching function for call to ‘CFastLED::addLeds(CRGB [32], int)’
its ok had to change led type but this code goes back and forth need it to just keep going round and round will use the code i have for now till i learn a bit more thanks for you help
@dave_windsor ah, right of course, you want the dot to go round and round. My bad.
Start with this simple loop:
Once you are comfortable with how its lighting up a pixel, and “moving” it along the strip, we can put your actual numbering into an array and read through that. Baby steps
cool thank ill have a look
Hi @dave_windsor just got in from work, and had a few minutes (before the domestic bliss breaks out) and put this example together
I’ve tested this on a strip here, and i’ve used the running order you gave me.
You will have to change your data pin etc. to match yours.
Also that error you mentioned is because i’d specified NEOPIXEL as the led type, but used the FastLED.addleds template for WS2811 led types.
I dont know what type of led you are using.
