Setting up a Smoothieboard for the first time. Almost got everything working. However, the extruder is not extruding appropriately.
I have a 200 step motor, 16 microstep stepper and a E3D Titan extruder. All these together I understand would be a 418.5 steps/mm.
Here is my extruder configuration:
Extruder module configuration
extruder.hotend.enable true # Whether to activate the extruder module at all. All configuration is ignored if false
extruder.hotend.steps_per_mm 418.5 # Steps per mm for extruder stepper
extruder.hotend.default_feed_rate 600 # Default rate ( mm/minute ) for moves where only the extruder moves
extruder.hotend.acceleration 500 # Acceleration for the stepper motor mm/sec²
extruder.hotend.max_speed 50 # mm/s
When I tell the extruder to manually feed 100mm of filament with this configuration, I get about 35mm. I tried tripling the steps_per_mm in the configuration (to 1245.5) and tried to feed 100mm of filament again. I got the EXACT same result of about 35mm (yes, I reset the Smoothieboard by powering it off and back on again). So, what does this mean???
One step further which I believe is the answer. The default extruder.hotend.steps_per_mm for Smoothieware is 140. This is almost EXACTLY 1/3 of mine and the fellow in the above link. And my extruder is extruding 1/3 of the amount of filament it is supposed to be. Which must mean that Smoothieware is still using the default value of 140 for extruding in my case instead of the value I have placed in it of 418.5.
do you have an override file? if you do then changing the config will not do anything, check with M503, if it is active then either use M92 Exxx to set steps/mm or do M502 to delete the override file. BTW this is explained on the wiki in pretty much the first section on config.
@Wolfmanjm Thanks for the reminder. I’ll check that again. Definitely different from how Marlin works (in a good way, but requires a change in perspective).
In a quick search on the http://smoothieware.org/configuring-smoothie page, config overrides, although mentioned in the table of contents, are not referred to at all until the end of the page btw.
I’d almost recommend having a section labeled For Marlin users to draw attention to specific differences these users would need to look for specifically.
