Can you show pictures and point to what you were adjusting and measuring on it? I think there’s a misunderstanding here but I’m not quite sure what it is, and a picture might help resolve it.
Sure!
but there is need some explanation.
Today I noticed that one wire from electric meter was almost broken I solder it and now it looks like it works - I mean Vref.
I set it to 1.08V (image). Between GND and EN - 5,07V
Well, that explains the problem with measuring the voltage! But it means I don’t see an easy answer.
I think that the “70% for safety” is probably related to confusion over RMS vs. peak current. If should be safe to run the steppers up to their rated current, but they should at least function at 1A.
Do you have any other stepper motors or stepsticks to swap to compare?
