Does this setting enable smoothieware?
I’m not sure exactly what you mean ( I know what advance is, just not sure what you are asking about it )
Are you asking whether smoothieware has a feature that is equivalent or the same as the Marlin linear advance feature?
Yes exactly.
No it doesn’t, we have found there’s at this point no clean and computing-efficient to do this in firmware, and as slicing programs ( Slic3r for example ) do this job very well, we rely on that.
I’m testing pellet extruder:
Author writes linear advance much improves quality.
Is there anything in Smoothie that you would reccommend for pellet extruders?
Linear advance is a parameter you can enable/tune in Slic3r
You are right and the only one I know. It’s missing in Prusa slicer unfortunately (I like it very much).
