Servo setup F1.
Thank you. This is a huge help. We are printing this out of PETG and PC here at Airwolf 3D on the new AXIOM printers. We would love to talk if you have time soon. My email is tyler@airwolf3d.com. Loving this build, thanks for sharing!
Ok, good to hear. I´ll try to add some documentation on how to set up the steering and servo.
And thanks for the kind words.
I was just trying to figure this out. Thank you
@Daniel_Noree this was my biggest issue, so what metal did you use for the servo linkage? I tried paper clip and it was no good. Thanks in advance.
@TinkerMake initially I used “piano wire” but it was pain to work with so lately I’ve been using 1,5mm alu welding rod.
@Daniel_Noree Ok, will need to look into that…I don’t have any welding rod laying around. Will post up if I find an alternative that works. Thanks.
