Serial Port JSON Server v1.83 just published.
Serial Port JSON Server v1.83 just published. Has fancy device detection with icons for known devices inside CP and a new Marlin buffer courtesy of +Peter van der Walt, plus an Arduino/Atmel firmware programmer courtesy of the Arduino.cc team.
Ok just tried the “new” JSON server and Im coming up with zip!
Started CP and noticed the update for JSOn to 1.83 needed to be downloaded because I had an error stating there was a newer version. Downloaded the new version, it found my arduino, set it for Grbl and I get “Line overflow” when I try to unlock! No matter what I try all I get is “Line overflow” and thats with gcode from several different souces.
Am I doing something wrong???
OK tried a different computer and now I get “ERROR Expected Command Letter”
I’m at a loss here since I am not very familiar with this program but have been using it successfully for the past few weeks until this latest update.
I should also add that the machine works fine when I use Inventables online program “Easel”, oh and this is on an X-Carve machine.
