Ok thanks for taking a look. I noticed it works every time on the top layer, only fails on the bottom layer which made me wonder if it was having an issue with the bottom layer for some reason.
I just nudged a couple of things and resaved and it appears to work now.
Is there any kind of log output that could help in identifying why the Eagle widget cant process a layer properly?
Also, is there any way to change the default settings in the Eagle widget?
I find I need the same settings each time, but in trouble shooting, I’m having to fill out those boxes ALOT which is a huge time waster.
There is a lot of debug info spit out into the Javascript console, but you do have to turn on the debug output. So hit ctrl+shift+j to show the Javascript console in your browser. Then go to this menu to turn on debug.
It’s such a great web app, but in dire need of workflow improvements, at least for me.
I got excited to see someone trying to get an offline version working, as they should allow user changes.
Alas I couldn’t get it working and seems untouched in 5 years
Having Eagle board import is a great time saver compared to other methods involving lots of converting.
But having to reset up the parameters each time (and perhaps forget one and mess the job up) kinda negates the benefits.
Is there any hope of things opening up again for forks etc?
At work, we open sourced our wrapper around the appengine APIs and then had to port everything over to new APIs. So a lot of what someone would need to do to move from the old APIs to the new APIs is basically encoded in commits here from about September 2019 to January 2020.
