S9 Y axis looses orgin
i have a issue with my S9 machine, it seems to have started after i calibrated the y and x axis, i was able to pin it down to only the y axis, i tested the x axis over and over and it never showed there. i start the machine in the proper location front let, make sure its connected, i have verified the machine measurements are all the same, so when i jog the y axis back and forth i get a crash, a stop for no reason, this only happens when i job the y axis over 200mm. it does not do it if iam jogging it under those measurements, the x axis can be jogged full length no issue. back to the y, the issue happens either when i jog it back or sent to back to orgin. now i have tried both lightburn and lasergrbl, it does the same thing in both software, i have tried 3 differnt computers same issue. something is going on with this axis.
please any suggestions or help, i would appreciate, it. Also i did follow all the tutorials ref first set up and software download .
Name.pdf (91.4 KB)
Name.pdf (91.4 KB)
I fixed the issue
