I wanted to revisit this question, I asked it about a year or more ago but technology changes daily it seems.
Is it possible to run two K40’s from one laptop? Could I have two sessions of K40 Whisperer running and each is connected to a separate laser? Thanks in advance.
By the way I have used a K40 for two years now for business engraving and these machines are great value for what you can do with them. Technically I am on my second machine but I have engraved probably 2000 items in the past 2 years.
I would expect it is possible and since K40 Whisperer is a python2 application you should be able to run it twice from 2 different sessions. I don’t do Windows but if that is your platform I would look for how you run it from a commandline and try it with two different DOS prompts opened.
I don’t have 2 M2Nano boards( only one ) so I can’t see if there’s any effect changing the connection port on each instance. They do run simultaneous.
