Running LW2 on RAMPS...
Running LW2 on RAMPS… Whats everyones favorite flavor of FW?
I have Franco Lanza’s branch of Marlin/Kimbra loaded but it’s not communicating… well… the server echo’s when the ramps board throws an SD card init error, but I can slam on connect all day and it wont link up… Ill drop out to another proven version until he gets it working… I went to his branch for the cooler/temp control integration, but it’s not more important to me than simply working…
Yes peter… I cross posted… sorry… running LW2
lol, thats the one im having trouble with…
I added the serial buffer mod to boards.txt and I still get the same issue…
I can see the unit in the SPJS and I can send it the initial Home command with the button in LW2, once the unit homes the screen says “K40 Laser cutter ready” and just sits there. X in the DRO says processing for a good min or two and then clears… its not until then that I can send another command to the machine… where then it hangs again…
-v shows LW2 asking over and over for M114 but the machine never returns the coords until it seems to time out whatever process it was hanging on to begin with…
