running latest version of smoothieware
My config file has this in it
Optional order in which axis will home, default is they all home at the same time,
If this is set it will force each axis to home one at a time in the specified order
Homing_order YXZ # Y axis followed by X then Z last
#move_to_origin_after_home false # Move XY to 0,0 after homing
#endstop_debounce_count 100 # Uncomment if you get noise on your endstops, default is 100
#endstop_debounce_ms 1 # Uncomment if you get noise on your endstops, default is 1 millisecond debounce
#home_z_first true # Uncomment and set to true to home the Z first, otherwise Z homes after XY
I am trying to set that to home Y then X then Z to minimise some crashes that could occur on my machine, But having that line uncommented, and changing it to YXZ does not make any difference.
