Run program ok but tool does not move in visualiser and the X Y and Z counters stay at 0.
When running Gcode program processes blocks ok and says ok, laser switches on and off. I do not have motors connected yet
I have UNO with grbl1.1. Imported Gcode that runs ok on GcodeSender.
I had great expectations of this software as it does it all.
Help please
It’s a grbl misconfiguration (probably should be $10=0 ). Please read the docs.
@Jorge_Robles I agree, $10 = 3 should be the default; both work and machine positions, as some senders display both. In grbl 1.1 things are different $10 = 0 is work position, $10 = 1 is machine position (default). LW4 wants only $10 = 0.
@Jorge_Robles Thanks for reply, problem is solved; you are correct $10=0, WPos reported.
Problem is now solved
