Gave it a quick run and ran into multiple minor issues.
New level knobs hit on the x axis motor when the z axis is at home… Printed new ones but will modify to use the aluminum ones.
Not sure if it is stepper calibration or current settings causing incorrect movement of the y axis. Extruder motor also not working correctly appears to be either weak or not calibrated correctly.
Will have to do a total calibration and reset the current to see what is causing issues. I used the default RBB Marlin settings so I am curious why it is not close to calibration. Oh well, this is why I enjoy making!
