Resources for Gridfinity
Here:
(also supports foam for a laser/CNC)
Just upload a photo of tools which includes a sheet of paper (A4 or Letter — configure in the Settings) and then arrange to make a bin (or cut a sheet of foam).
Every other link on that page, like the menu bar and footer, appears dead. Just the app. Interesting.
Yeah, the contact e-mail doesn’t work either.
Wonder if it is supposed to still be in testing to a limited group, but the site admin failed to implement a whitelist for access or something along those lines.
Have you made any tool traces with this app?
This looks like a great idea.
I just ran a standard pair of scissors through it and it recognizes the shape very well.
When I export to an svg and import into fusion 360, the dimensions are way off. If I apply a magic scaling multiplier, it gets in the ballpark, but not anywhere near the type of fit I like for my gridfinity bins.
It looks like an offshoot project from https://www.rocketbrackets.com/, which was the domain of the contact info email. I didn’t look any further than that though.
Different site hoeing this row as well:
Rather than make a bunch of different threads, figured this was better as just a general discussion of this organizing system (anyone else doing it?)
This video seemed a well-reasoned discussion of what one machinist working with it learned and how things turned out:
(I really like the aesthetics of it, and will probably do something similar for at least one set of my tools)
Another notable video:
Initial release of “Gridfinity/2” a 21mm version:
Did finally print one of the cases and a full set of inserts:
which is a bit more space-efficient than the (unfortunately discontinued) Storehouse 10-tray utility box which it is replacing.
The case in question is from:
https://shapescan.pt/
you download a A4 or US letter pdf with markers take a picture of an object inside the sheet and get 3 types of files to download with the outline corrected for scale and lens distortion
Why that rather than
or
https://all3dp.com/6/tooltrace-ai-uses-photos-of-your-tools-and-generates-3d-printable-gridfinity-organizers/
For understand why mine is just testing.
Mine is more precise.
And using arucos to correct lens distortion the ideia was mine. Thats why for mine you only need to print 4 arucos in the sheet where then a grill with them.
Also in the next update will be possivel to transform something that you draw in the sheet
