I’ve read inconsistent topics about the grbl-LPC. In some topics is written it’s not possible to use with boards which don’t have built-in drivers. In other topics there is the re-ARM board is supported by the grbl-LPC.
Can you help me please if I can install the grbl-LPC firmware to my re-ARM boards or not? I’d like to use this board for my coreXY CNC machine based on The Ant project. If yes, is there a useable coreXY configuration file for the re-ARM board?
It’s not really whether the drivers are on the board that matters, but it happens that at least many such don’t have a pin-out that is compatible with the smoothieware pinout.
If it is not supported, then see grblHAL:
Re-ARM is included in the supporte boards for grblHAL, as are the SKR 1.3 and 1.4:
