Quick question. Why is it that ever since I used the raft setting once it forces me to have 1 raft layer on all my slicer profiles? I set it to zero and it replaces it with 1 when i save. Using slicer 0.9.9
Sounds like a bug. Try manually editing the config file for the profile you’re using. I’ve had this problem with other settings in the past and editing the file directly seems to work.
+1 for @Tim_Rastall 's suggestion - Slic3r has a bug where it will not accept new values for settings that have an error in the config.
