There’s an assembly “XY_Axis_A” and another “XY_Axis_A (Driven Version/Configuration)” - is this ‘and’ (I need them both) or ‘or’ (I need just one of them)?
What’s the significance of the lines with green background as opposed to white background?
It would be helpful to have a photo or exploded diagram of each subassembly. Is that what’s in ‘Solidworks/Sub Assemblies’ directory? I’m on Ubuntu and I can’t figure out how to view those files (say in Blender). Help appreciated!
One side has a longer shaft that extends outside the frame and has a pulley, that pulley is then coupled via a belt to a drive assembly which consists of a mount, motor, and motor pulley.
I have known for a long time I need to do some better documentation. Exploded views would be great. And If anybody is willing to help with some of those it would be amazing.
I hope to get around to it eventually. I apologize that I have not done it so far. Life just gets in the way at times.
I’ve tried AutoDesk Viewer and Onshape with the files in the ‘Solidworks/Sub Assemblies’ directory and they both say that the SolidWorks files are malformed or in an unsupported form.
Onshape says "It looks like you want to import a SolidWorks assembly. Onshape needs a SolidWorks Pack and Go .zip file to import a SolidWorks assembly with all of its parts. Learn more: https://cad.onshape.com/help/index.htm#cshid=importfiles "
@Don_Barthel X_T imports nicely into Onshape. X_T is basically the backbone of the Solidworks file format… and then Solidworks loads a tone of metadata on top of the X_T file. So X_T is the best Import/Export from Solidworks if you can do it.
i think that the eDrawings for Solidworks, even as buggy as it it, is the best for viewing the full model. You can get extended meta-data on the part and even generate single part drawings from the model if you need.
Exporting to any Autodesk product for me lost all extended info and assemblies got all jumbled around due to what F360/Acad considered insertion points. YMMV.
