Question about putting together a custom PCB to help me clean up my new light project. I have 4 windows each with a 4m strip of Neopixels, running from a Mega with FastLED. My question is, using ExpressPCB (or any board service I guess) to build a custom PCB, how big do the +5v power traces need to be for each strip? Has anyone done this? Can anyone help me? I don’t think a 4m strip would draw that much power, but voltage drops and overheating a trace are a concern (it’s under my couch in the living room). Note that they may be running all white, but brightness will be 75% or less most of the time (they are very bright otherwise), and generally, they will just be blinking some representation of holiday colors. Well, on the 4th, one window will be white 100% of the time in a flag layout (less bright though).
Thoughts? I really just want to do this with cheap stuff from Fry’s and Adafruit, but don’t want to burn down the house, or watch the lights fade or blink out due to a voltage drop.
Thank you for the link. I’m pretty sure based on the Neopixel descriptions that < 500 will no draw 30 amps. I suspect it’s far less than that. But, I need to figure out the specifics before I do this. I’m hoping someone else has done something similar and can provide feedback on experience.
I do have experience with PCB design and have some experience with multi RGB LED projects… and of course it is likely to be far less current in a typical animation but…
you are concerned with voltage drop and heat and I would recommend that you design with maximums in mind.
Please remember you will be sticking this under a couch in your living room !!!
That was the suggestion from the guys here at work. And ExpressPCB has some guidelines that seem awfully small, but the added wire would work just as well. Thanks for the help.
I did not look into the ExpressPCB guidelines but would assume they describe individual power traces to small components and ICs not a heavy current distribution scheme.
Well… you indicated that their guidelines seem awfully small but I see now that they do provide a sensible PCB design guideline for heavy power traces.
Good luck with your design and make sure you show off your work when it is ready !
