Hello,
I am new here. I am having problems with my extruder. The motor was running well before starting any test. Even when I try to extrude 50mm I get 50mm out. So when I said to myself that it’s good time to print my first part I found myself faced with this problem: the axes move and start to print but the extruder motor does not turn ( it tries to turn but without success). And that’s just when I try to print a part!
I had doubts about the filament I am using, so I cleaned everything and changed the filament, but without success. So I made another impression but now without using any filament just to see if the motor will run or not. But still without result.
Any help please…
Thank you.
