[Project CNC] Technical Feedback Request: Specialized Vertical CNC (Micro-drilling & Axial Pin Insertion)
Hello everyone,
I am designing a custom 3-axis CNC machine for a specialized application: vertical micro-drilling and precise axial pin insertion/guiding into rigid composite/panel materials (working area approx. 400x400 mm to 500x500 mm).
Since there is no lateral milling or side-milling involved, the mechanical constraints are purely axial along the Z-axis. My primary priorities are high repeatability, long-term reliability, low maintenance, and low noise level for indoor operation.
Here is the proposed hardware, dimensions, and architectural breakdown:
  1. Frame & Structure:
  • Base & Gantry: Heavy-duty aluminum extrusions — 40x80 mm for the main base/load-bearing frame, and 20x80 mm / 20x40 mm for the moving gantry.
  • Motion Guidance:
    • X & Y axes: MGN12H linear rails (12 mm wide rail guides with long-block carriages).
    • Z axis: MGN15H linear rails for enhanced rigidity under vertical load.
  • Drive System:
    • T8 Lead Screws with an outer diameter of 8 mm and a lead of 2 mm (or 4 mm) paired with anti-backlash brass/POM nuts on X, Y, and Z.
    • Chosen over belt drives for high precision, mechanical self-locking under load, and silent operation.
  1. Electronics & Control:
  • Mainboard: BigTreeTech Octopus Pro (32-bit ARM Cortex-M4, STM32F429).
  • Stepper Drivers: TMC2209 running in StealthChop2 mode for near-silent motion.
  • Motors: NEMA 17 high-torque stepper motors (standard 42x42 mm faceplate, 40 mm to 48 mm body length, holding torque ~0.4 to 0.65 Nm).
  • Power Supply: Mean Well LRS-350-24 (24V DC, 14.6A).
  • Connectivity: GX16 aviation connectors (16 mm panel-mount plugs) & WAGO 221 lever nuts for clean, modular wiring.
  1. Toolhead & Operations:
  • Primary Function: High-rpm micro-drilling (tool shank diameter 3.175 mm / 1/8") followed by automated Z-axis axial press/insertion.
  • Load Profile: Pure vertical downward force during insertion (~50 to 100N), zero side-load/shear force on the frame.
Questions for the community:
  1. Drive Selection: Given the low travel speed requirements and emphasis on axial load and silent operation, do you foresee any issues with T8x2 (or T8x4) lead screws on X/Y vs. SFU1204 ball screws (12 mm diameter, 4 mm lead) regarding whip or wear?
  2. Stepper Thermal Load: Under sustained holding torque during vertical insertion using NEMA 17 motors, are TMC2209 drivers sufficient, or would upgrading to TMC5160 / external drivers offer a noticeable reliability gain?
  3. Frame Rigidity: Are 4080/2080 extrusions combined with MGN12/MGN15 rails sufficient to prevent frame flex under repetitive ~50-100N vertical pressing forces across a ~500 mm span?
Thanks in advance for your technical insights and suggestions!
Personally I’ve been using 8mm 4 start lead screws on a couple machines I’ve assembled and am happy with the accuracy. I don’t care for brass antibacklash nuts though, as I’ve found they are kind of noisy even with lubrication. Nema 17 might be fine for your application, but I might go for nema 23 for the extra torque which you might need to lift your Z axis. I guess as far as extrusion is concerned, I’d go C beam, and check out the heavy that Makerstore sells. In the end I guess you build it and find out if it meets the requirement you need.
