Hi there.
I probably need some help. I need to be able to do suface levelling. and just can’t get it to play.
I use GRBL 1.1f ( blackbox ) and usually use Openbuild control software. on windows 10
firstly i have big problems getting it to connect to the controller and then get an open door alarm all the time.
I’ve managed to get it to start leveling twice, but after 3 points it stops, and yes, it doesn’t want to anymore.
Is it meant that, after running levelling, you run the job in Chillipeppr, or do I save the file and run in e.g. openbuild control ?
Hope someone has a few tips for a newbie
Regards Lars
