I have a home-built 420x550 machine that I am having a heck of a time configuring the movement controls. I have proper direction, but getting the $100-$102 settings to match up with the microstep settings has me flummoxed. Here are my machines physicals:
X distance 420mm, Y distance 550mm
Single screw controls each axes.
Y-axis is 800mm Tr8x8 Lead Screw (Acme Thread, 2mm Pitch, 4 Starts, 8mm Lead)
X-axis is 550mm Tr8x8 Lead Screw (Acme Thread, 2mm Pitch, 4 Starts, 8mm Lead)
Z-axis is 300mm Tr8x8 Lead Screw (Acme Thread, 2mm Pitch, 4 Starts, 8mm Lead)
Stepper Motors:
NEMA23
Step Angel 1.8Β°
G-code
$0=10
$1=25
$2=0
$3=2
$4=0
$5=0
$6=0
$10=115
$11=1.000
$12=0.002
$13=0
$20=0
$21=0
$22=0
$23=7
$24=25.000
$25=500.000
$26=250
$27=2.000
$30=10000
$31=0
$32=0
$100=400.000
$101=400.000
$102=400.000
$110=1200.000
$111=1200.000
$112=600.000
$120=200.000
$121=200.000
$122=100.000
$130=400.000
$131=180.000
$132=80.000
Drivers are set to 16 microsteps (off, off, on)
Here is the issue: by my calculations, this should not work, but is the closest I have found to getting the movement distance correct. I am using $100 = (ππ‘πππ ππππ
ππ£πππ’π‘πππ x ππππππ π‘πππ ) /Mπππππππ‘πππ πππ π
ππ£πππ’π‘πππ
which should come out to (200 x 16) / 2 = 1600. When I put that into $100 my machine flys way past the mark. I dont get what I am doing wrong here.
