I’m looking for feature recommendations or buying advice for a printer that will be exclusively used to print petg.
mostly transparent filiment.
It’s going to be set up in a room that is already climate controlled so there won’t be any problems with moisture absorption. I store my petg there so it’s logical to set up a printer there as well.
what I need is an entry level size machine that can stay per intently set up in an optimal configure, and and I just want it to print the same configuration first time every time, I won’t be changing anything once it’s set up.
no fancy bell and whistles, it doesn’t even need WiFi, it just needs to be reliable.
ender 3 scale build volume and about 15 hours a week printing.
I’m not wed to any slicer software.
budget, under 300 dollars, the more under the better.
