Printed in 3h on my mendel90. The 0.8 nozzle is good for some impressive speed!
100x100x150mm 10mm wall objekt, 10% infill.
Good experiment and result. Thanks for sharing. Did you drill out the nozzle to .8 yourself? Have you a convenient way of changing to other sizes? Surface finish looks very acceptable.
Thanks! The nozzle is a e3d oem. The e3d makes it kind of easy to change. But i must recalibrate the z probe offset.
Do post on your z-probe on the M90. Would be interesting to see some picts and detail on how you got on rigging that also.
Yep, sometimes superfine detail is not what you need.
I will poste some pictures on the probe setup later
