Using slic3r 1.3.1, mks gen 1.3 (~2017year), last ver BIN of smoothie.
Gcode printing does not finish, the printer stops, the fans stop, the menu does not respond to user actions.
If you repeat the gcode print, it will break off at the same place. On one of the forums, they suggested the decision to use the "use relative E distance "option in the print settings.
Slic3r ->Printer Settings->Advanced
For some reason, the G92 E0 instruction gives a print stop.
