Oops. I forgot that PCBs have tiny holes. The existing ops would break drills. If you have a mill bit < 0.8mm, and the holes are separate from the trace objects, then cut inside might work. It’s risky though, a mill that small probably won’t survive plunging through.
@Todd_Fleming How about scaling down the hole dia to 0.1mm and then use a mill operation for drilling the 0.8mm hole. I think the drill can handle that.
Or you add a specific drill operation.
Well, my router still uses a .9 grbl board so I used lw4 to generate the gcode but other crappy software to actually do the cutting.
For the holes I used cut inside with the holes being a .5 diameter with my .5 bit…
This didn’t work… What it seems to do is pick a point around the circumference and drills down from there so all my holes were off, all of them in different places.
Wasn’t sure if it was a miss step issue or not, so ran the cut three times. Once on wood and another twice on the copper clad board. All of the holes are in the same place on all three cuts.
