Are those patterns from a test fire of a single test fire? If so, then your tube has shifted mode and there is nothing you can do but get a new tube. The references HalfNormal posted about talk about laser (TEM) modes, but I see the link for the first one is now dead.
Why this happened is hard to say. Mostly likely either your tube has leaked gas or something changed / failed with the optical ends of the tube.
