Please help.. I'm getting a shift between the engrave and cut jobs..
Please help… I’m getting a shift between the engrave and cut jobs… I have tried combining engrave and cut jobs together and tried separately… Unchecked the print icon in the layers menu… All prints perfectly except the cut layer is offset… Anyone seen this? Is it a simple fix? It doest matter if I do single cut/engrave job or if I try multiple… Thanks in advance Chris…
The fix I’ve used is to use a registration dot in the upper left that both the engrave and cut jobs include. It’s kind of a hack but does the trick. There’s probably a better way…
That’s how I do it, too. I make a new layer called “corner”, and place a small circle in the top left just above the working area. Ensure you always “print” the corner layer.
It’s an unfortunate consequence of CorelLaser trying to line up the work with the 0,0 coordinate.
Yeah!!! That did it… Thanks for your rapid replies… Love this group…
Alternatively, I place everything inside a rectangle 300x200mm. The rectangle has no border & no fill, it’s just an alignment box. Then I align all the objects where they need to go in that rectangle & group them. Both engrave jobs & cut jobs have corresponding rectangles to keep the items aligned with the other job.
I don’t use a dot. In print preview of your layers, check to make sure your work aligns with the upper left corner(blue arrow in corel indicates where the work corner is). In my experience text boxes or any other object that takes up space outside your work area will cause this to happen. Use process of elimination to find out where the problem is. Delete text objects first one at a time, go to print preview and see if your alignment issues are solved. Undo delete if not. Again, anything that minutely falls out of your workspace will cause the program to shift it in order to fit.
@Yuusuf_Sallahuddin_Y That invisible rectangle trick works great! Thanks!
