Hi,
I have a big problem with the software CorelLaser
When they start they say “Pirated UKey”
Please Help me
For many years a lot of these software companies made it mandatory that you use a ‘usb key’ to access the software.
Sounds like that’s what you have along with a hacked usb key.
Where did you get the software?
I installed this software on another laptop, and it works.
Does it also use a key?
Lightburn creates a ‘key’ based on the machines internals, if you move it you loose that part of functionality.
If it says the USB key is missing, you might need to talk with the vendor and ask them why it isn’t functioning on both computers.
So, indirectly, is the key still stuck on the other computer? Is there a way to release it from the previous computer?
so initially I used the key on computer “A” then the computer was broken and finally I changed it to computer “B” after I used the key earlier on computer “B” it did not work
The usb key didn’t get overwritten did it?
Don’t know what else to suggest, but contact the vendor.
