Here is config file
- Smoothieboard configuration file, see onfiguring-smoothie
- NOTE Lines must not exceed 132 characters, and ‘#’ characters mean what follows is ignored
## Robot module configurations : general handling of movement G-codes and slicing into moves
- Basic motion configuration
default_feed_rate 4000 # Default speed (mm/minute) for G1/G2/G3 moves
default_seek_rate 4000 # Default speed (mm/minute) for G0 moves
mm_per_arc_segment 0.0 # Fixed length for line segments that divide arcs, 0 to disable
#mm_per_line_segment 5 # Cut lines into segments this size
mm_max_arc_error 0.01 # The maximum error for line segments that divide arcs 0 to disable
# note it is invalid for both the above be 0
# if both are used, will use largest segment length based on radius
delta_segments_per_second 200 # For deltas only, number of segments per second, set to 0 to disable
# and use mm_per_line_segment
- Arm solution configuration : Cartesian robot. Translates mm positions into stepper positions
alpha_steps_per_mm 200 # Steps per mm for alpha ( X ) stepper and tower
beta_steps_per_mm 200 # Steps per mm for beta ( Y ) stepper and tower
gamma_steps_per_mm 200 # Steps per mm for gamma ( Z ) stepper and tower
- Delta configuration
arm_solution linear_delta # Selects the linear delta arm solution
arm_length 215.0 # This is the length of an arm from hinge to hinge
arm_radius 105.0 # This is the horizontal distance from hinge to hinge when the effector is centered
- Planner module configuration : Look-ahead and acceleration configuration
acceleration 3000 # Acceleration in mm/second/second.
#z_acceleration 500 # Acceleration for Z only moves in mm/s^2, 0 uses acceleration which is the default. DO NOT SET ON A DELTA
junction_deviation 0.05 # See
#z_junction_deviation 0.0 # For Z only moves, -1 uses junction_deviation, zero disables junction_deviation on z moves DO NOT SET ON A DELTA
- Cartesian axis speed limits
#x_axis_max_speed 30000 # Maximum speed in mm/min
#y_axis_max_speed 30000 # Maximum speed in mm/min
#z_axis_max_speed 30000 # Maximum speed in mm/min
- Stepper module configuration
- Pins are defined as ports, and pin numbers, appending “!” to the number will invert a pin
alpha_step_pin 2.1 # Pin for alpha stepper step signal
alpha_dir_pin 0.11! # Pin for alpha stepper direction, add ‘!’ to reverse direction
alpha_en_pin 0.10 # Pin for alpha enable pin
alpha_current 2.5 # X stepper motor current
alpha_max_rate 30000.0 # Maximum rate in mm/min
x_axis_max_speed 30000.0 # mm/min
beta_step_pin 2.2 # Pin for beta stepper step signal
beta_dir_pin 0.20! # Pin for beta stepper direction, add ‘!’ to reverse direction
beta_en_pin 0.19 # Pin for beta enable
beta_current 2.5 # Y stepper motor current
beta_max_rate 30000.0 # Maxmimum rate in mm/min
y_axis_max_speed 30000.0 # mm/min
gamma_step_pin 2.3 # Pin for gamma stepper step signal
gamma_dir_pin 0.22! # Pin for gamma stepper direction, add ‘!’ to reverse direction
gamma_en_pin 0.21 # Pin for gamma enable
gamma_current 2.5 # Z stepper motor current
gamma_max_rate 30000.0 # Maximum rate in mm/min
z_axis_max_speed 30000.0 # mm/min
## Extruder module configuration
extruder.hotend.enable true # Whether to activate the extruder module at all. All configuration is ignored if false
extruder.hotend.steps_per_mm 450 # Steps per mm for extruder stepper
extruder.hotend.default_feed_rate 600 # Default rate ( mm/minute ) for moves where only the extruder moves
extruder.hotend.acceleration 500 # Acceleration for the stepper motor mm/sec²
extruder.hotend.max_speed 50 # Maximum speed in mm/s
extruder.hotend.step_pin 2.0 # Pin for extruder step signal
extruder.hotend.dir_pin 0.5! # Pin for extruder dir signal ( add ‘!’ to reverse direction )
extruder.hotend.en_pin 0.4 # Pin for extruder enable signal
- Extruder offset
extruder.hotend.x_offset 0 # X offset from origin in mm
extruder.hotend.y_offset 0 # Y offset from origin in mm
extruder.hotend.z_offset 0 # Z offset from origin in mm
- Firmware retract settings when using G10/G11, these are the defaults if not defined, must be defined for each extruder if not using the defaults
extruder.hotend.retract_length 3 # Retract length in mm
extruder.hotend.retract_feedrate 45 # Retract feedrate in mm/sec
extruder.hotend.retract_recover_length 0 # Additional length for recover
extruder.hotend.retract_recover_feedrate 8 # Recover feedrate in mm/sec (should be less than retract feedrate)
extruder.hotend.retract_zlift_length 0 # Z-lift on retract in mm, 0 disables
extruder.hotend.retract_zlift_feedrate 6000 # Z-lift feedrate in mm/min (Note mm/min NOT mm/sec)
delta_current 1.0 # First extruder stepper motor current
- Second extruder module configuration
extruder.hotend2.enable true # Whether to activate the extruder module at all. All configuration is ignored if false
extruder.hotend2.steps_per_mm 140 # Steps per mm for extruder stepper
extruder.hotend2.default_feed_rate 600 # Default rate ( mm/minute ) for moves where only the extruder moves
extruder.hotend2.acceleration 500 # Acceleration for the stepper motor, as of 0.6, arbitrary ratio
extruder.hotend2.max_speed 50 # mm/s
extruder.hotend2.step_pin 2.8 # Pin for extruder step signal
extruder.hotend2.dir_pin 2.13 # Pin for extruder dir signal ( add ‘!’ to reverse direction )
extruder.hotend2.en_pin 4.29 # Pin for extruder enable signal
extruder.hotend2.x_offset 0 # x offset from origin in mm
extruder.hotend2.y_offset 25.0 # y offset from origin in mm
extruder.hotend2.z_offset 0 # z offset from origin in mm
#epsilon_current 1.5 # Second extruder stepper motor current
## Laser module configuration
laser_module_enable false # Whether to activate the laser module at all
laser_module_pwm_pin 2.7 # This pin will be PWMed to control the laser.
# Only pins 2.0, 2.1, 2.2, 2.3, 2.4, 2.5, 1.18, 1.20, 1.21, 1.23, 1.24, 1.26, 3.25 and 3.26
# can be used since laser requires hardware PWM,
#laser_module_ttl_pin 1.30 # This pin turns on when the laser turns on, and off when the laser turns off.
#laser_module_maximum_power 1.0 # This is the maximum duty cycle that will be applied to the laser
#laser_module_minimum_power 0.0 # This is a value just below the minimum duty cycle that keeps the laser
# active without actually burning.
#laser_module_default_power 0.8 # This is the default laser power that will be used for cuts if a power has not been specified. The value is a scale between
# the maximum and minimum power levels specified above
#laser_module_pwm_period 20 # This sets the pwm frequency as the period in microseconds
## Temperature control configuration
- First hotend configuration
temperature_control.hotend.enable true # Whether to activate this ( “hotend” ) module at all.
temperature_control.hotend.thermistor_pin 0.23 # Pin for the thermistor to read
temperature_control.hotend.heater_pin 2.5 # Pin that controls the heater, set to nc if a readonly thermistor is being defined
temperature_control.hotend.thermistor Semitec # See
#temperature_control.hotend.beta 4066 # Or set the beta value
temperature_control.hotend.set_m_code 104 # M-code to set the temperature for this module
temperature_control.hotend.set_and_wait_m_code 109 # M-code to set-and-wait for this module
temperature_control.hotend.designator T # Designator letter for this module
temperature_control.hotend.max_temp 250 # Set maximum temperature - Will prevent heating above 300 by default
#temperature_control.hotend.min_temp 0 # Set minimum temperature - Will prevent heating below if set
- Safety control is enabled by default and can be overidden here, the values show the defaults
#temperature_control.hotend.runaway_heating_timeout 900 # How long it can take to heat up, max is 2040 seconds.
#temperature_control.hotend.runaway_cooling_timeout 0 # How long it can take to cool down if temp is set lower, max is 2040 seconds
#temperature_control.hotend.runaway_range 5 # How far from the set temperature it can wander, max setting is 63°C
#temperature_control.hotend.runaway_error_range 2
- Bang-bang ( simplified ) control
#temperature_control.hotend.bang_bang true # Set to true to use bang bang control rather than PID
#temperature_control.hotend.hysteresis 2.0 # Set to the temperature in degrees C to use as hysteresis
- PID configuration
temperature_control.hotend.p_factor 63.1 # P ( proportional ) factor
temperature_control.hotend.i_factor 5.200 # I ( integral ) factor
temperature_control.hotend.d_factor 191 # D ( derivative ) factor
#temperature_control.hotend.max_pwm 64 # Max pwm, 64 is a good value if driving a 12v resistor with 24v.
- Second hotend configuration
#temperature_control.hotend2.enable true # Whether to activate this ( “hotend” ) module at all.
#temperature_control.hotend2.thermistor_pin 0.25 # Pin for the thermistor to read
#temperature_control.hotend2.heater_pin 1.23 # Pin that controls the heater
#temperature_control.hotend2.thermistor EPCOS100K #
##temperature_control.hotend2.beta 4066 # or set the beta value
#temperature_control.hotend2.set_m_code 104 # M-code to set the temperature for this module
#temperature_control.hotend2.set_and_wait_m_code 109 # M-code to set-and-wait for this module
#temperature_control.hotend2.designator T1 # Designator letter for this module
#temperature_control.hotend2.p_factor 13.7 # P ( proportional ) factor
#temperature_control.hotend2.i_factor 0.097 # I ( integral ) factor
#temperature_control.hotend2.d_factor 24 # D ( derivative ) factor
#temperature_control.hotend2.max_pwm 64 # Max pwm, 64 is a good value if driving a 12v resistor with 24v.
temperature_control.bed.enable true # Whether to activate this ( “hotend” ) module at all.
temperature_control.bed.thermistor_pin 0.24 # Pin for the thermistor to read
temperature_control.bed.heater_pin 2.7 # Pin that controls the heater
temperature_control.bed.thermistor EPCOS100K #
#temperature_control.bed.beta 3974 # Or set the beta value
temperature_control.bed.set_m_code 140 # M-code to set the temperature for this module
temperature_control.bed.set_and_wait_m_code 190 # M-code to set-and-wait for this module
temperature_control.bed.designator B # Designator letter for this module
#temperature_control.bed.bang_bang false # Set to true to use bang bang control rather than PID
#temperature_control.bed.hysteresis 2.0 # Set to the temperature in degrees C to use as hysteresis
temperature_control.bed.p_factor 83.0 # P ( proportional ) factor
temperature_control.bed.i_factor 2.194 # I ( integral ) factor
temperature_control.bed.d_factor 786 # D ( derivative ) factor
temperature_control.bed.max_temp 60 # Set maximum temperature - Will prevent heating above 300 by default
## Switch modules
- Switch module for fan control
switch.fan.enable true # Enable this module
switch.fan.input_on_command M106 # Command that will turn this switch on
switch.fan.input_off_command M107 # Command that will turn this switch off
switch.fan.output_pin 2.4 # Pin this module controls
switch.fan.output_type pwm # PWM output settable with S parameter in the input_on_comand
#switch.fan.max_pwm 255 # Set max pwm for the pin default is 255
#switch.misc.enable true # Enable this module
#switch.misc.input_on_command M42 # Command that will turn this switch on
#switch.misc.input_off_command M43 # Command that will turn this switch off
#switch.misc.output_pin 2.4 # Pin this module controls
#switch.misc.output_type digital # Digital means this is just an on or off pin
## Temperatureswitch
- Automatically toggle a switch at a specified temperature. Different ones of these may be defined to monitor different temperatures and switch different swithxes
- Useful to turn on a fan or water pump to cool the hotend
#temperatureswitch.hotend.enable true #
#temperatureswitch.hotend.designator T # first character of the temperature control designator to use as the temperature sensor to monitor
#temperatureswitch.hotend.switch misc # select which switch to use, matches the name of the defined switch
#temperatureswitch.hotend.threshold_temp 60.0 # temperature to turn on (if rising) or off the switch
#temperatureswitch.hotend.heatup_poll 15 # poll heatup at 15 sec intervals
#temperatureswitch.hotend.cooldown_poll 60 # poll cooldown at 60 sec intervals
## Endstops
endstops_enable true # The endstop module is enabled by default and can be disabled here
delta_homing true # Forces all three axis to home a the same time regardless of what is specified in G28
#alpha_min_endstop nc #1.24!^ # Pin to read min endstop, add a ! to invert if endstop is NO connected to ground
alpha_max_endstop 1.25^ # Pin to read max endstop, uncomment this and comment the above if using max endstops
alpha_homing_direction home_to_max # Or set to home_to_max and set alpha_max and uncomment the alpha_max_endstop
alpha_max 0 # This gets loaded as the current position after homing when home_to_max is set
#beta_min_endstop nc #1.26!^ # Pin to read min endstop, add a ! to invert if endstop is NO connected to ground
beta_max_endstop 1.27^ # Pin to read max endstop, uncomment this and comment the above if using max endstops
beta_homing_direction home_to_max # Or set to home_to_max and set alpha_max and uncomment the alpha_max_endstop
beta_max 0 # This gets loaded as the current position after homing when home_to_max is set
#gamma_min_endstop nc #1.29!^ # Pin to read min endstop, add a ! to invert if endstop is NO connected to ground
gamma_max_endstop 1.28^ # Pin to read max endstop, uncomment this and comment the above if using max endstops
gamma_homing_direction home_to_max # Or set to home_to_max and set alpha_max and uncomment the alpha_max_endstop
gamma_max 242.0 # This gets loaded as the current position after homing when home_to_max is set
alpha_max_travel 1000 # Max travel in mm for alpha/X axis when homing
beta_max_travel 1000 # Max travel in mm for beta/Y axis when homing
gamma_max_travel 1000 # Max travel in mm for gamma/Z axis when homing
- Endstops home at their fast feedrate first, then once the endstop is found they home again at their slow feedrate for accuracy
alpha_fast_homing_rate_mm_s 100 # Alpha tower fast homing feedrate in mm/second
alpha_slow_homing_rate_mm_s 20 # Alpha tower slow homing feedrate in mm/second
beta_fast_homing_rate_mm_s 100 # Beta tower fast homing feedrate in mm/second
beta_slow_homing_rate_mm_s 20 # Beta tower slow homing feedrate in mm/second
gamma_fast_homing_rate_mm_s 100 # Gamma tower fast homing feedrate in mm/second
gamma_slow_homing_rate_mm_s 20 # Gamma tower slow homing feedrate in mm/second
alpha_homing_retract_mm 5 # Distance to retract from the endstop after it is hit for alpha/X
beta_homing_retract_mm 5 # Distance to retract from the endstop after it is hit for beta/Y
gamma_homing_retract_mm 5 # Distance to retract from the endstop after it is hit for gamma/Z
- Endstop debouncing options
#endstop_debounce_count 100 # Uncomment if you get noise on your endstops, default is 100
#endstop_debounce_ms 1 # Uncomment if you get noise on your endstops, default is 1 millisecond debounce
- Endstop trim options
alpha_trim 0 # Software trim for alpha stepper endstop (in mm)
beta_trim 0 # Software trim for beta stepper endstop (in mm)
gamma_trim 0 # Software trim for gamma stepper endstop (in mm)
- End of endstop config
- Delete the above endstop section and uncomment next line and copy and edit Snippets/abc-endstop.config file to enable endstops for ABC axis
#include abc-endstop.config
## Z-probe
zprobe.enable false #true # Set to true to enable a zprobe
zprobe.probe_pin 1.29!^ # Pin probe is attached to, if NC remove the !
zprobe.slow_feedrate 5 # Mm/sec probe feed rate
#zprobe.debounce_count 100 # Set if noisy
zprobe.fast_feedrate 100 # Move feedrate mm/sec
zprobe.probe_height 5 # How much above bed to start probe
#gamma_min_endstop nc # Normally 1.28. Change to nc to prevent conflict,
Levelling strategy
Example for the delta calibration strategy
leveling-strategy.delta-calibration.enable true # Enable basic delta calibration
leveling-strategy.delta-calibration.radius 80 # the probe radius
- Example for the delta grid leveling strategy
leveling-strategy.delta-grid.enable true # Enable grid leveling
leveling-strategy.delta-grid.radius 40 # Grid radius in millimeters
leveling-strategy.delta-grid.size 7 # Grid size, must be an odd number
leveling-strategy.delta-grid.do_home true # Whether to home before calibration
leveling-strategy.delta-grid.save true # Whether to automatically save the grid
leveling-strategy.delta-grid.initial_height 10 # Height at which to start probling
- Panel
panel.enable true # set to true to enable the panel code
- Reprap discount GLCD with ribbon cables, and 5V broken out
panel.lcd reprap_discount_glcd # set type of panel
panel.spi_channel 0 # set spi channel to use P0_18,P0_15 MOSI,SCLK
panel.spi_cs_pin 0.16 # set spi chip select
panel.encoder_a_pin 3.25!^ # encoder pin
panel.encoder_b_pin 3.26!^ # encoder pin
panel.click_button_pin 2.11!^ # click button
panel.encoder_resolution 4 # override number of clicks to move 1 item (default is 4)
#panel.button_pause_pin 1.22^ # kill/pause set one of these for the auxilliary button on viki2
#panel.back_button_pin 1.22!^ # back button recommended to use this on EXP1
panel.buzz_pin 1.30 # pin for buzzer on EXP2
panel.external_sd true # set to true if there is an extrernal sdcard on the panel
panel.external_sd.spi_channel 0 # set spi channel the sdcard is on
panel.external_sd.spi_cs_pin 1.23 # set spi chip select for the sdcard
panel.external_sd.sdcd_pin 1.31!^ # sd detect signal (set to nc if no sdcard detect)
panel.menu_offset 1 # some panels will need 1 here
- Example for reprap discount GLCD
- on glcd EXP1 is to left and EXP2 is to right, pin 1 is bottom left, pin 2 is top left etc.
- +5v is EXP1 pin 10, Gnd is EXP1 pin 9
#panel.lcd reprap_discount_glcd #
#panel.spi_channel 0 # SPI channel to use ; GLCD EXP1 Pins 3,5 (MOSI, SCLK)
#panel.spi_cs_pin 0.16 # SPI chip select ; GLCD EXP1 Pin 4
#panel.encoder_a_pin 3.25!^ # Encoder pin ; GLCD EXP2 Pin 3
#panel.encoder_b_pin 3.26!^ # Encoder pin ; GLCD EXP2 Pin 5
#panel.click_button_pin 1.30!^ # Click button ; GLCD EXP1 Pin 2
#panel.buzz_pin 1.31 # Pin for buzzer ; GLCD EXP1 Pin 1
#panel.back_button_pin 2.11!^ # Back button ; GLCD EXP2 Pin 8
panel.alpha_jog_feedrate 6000 # X jogging feedrate in mm/min
panel.beta_jog_feedrate 6000 # Y jogging feedrate in mm/min
panel.gamma_jog_feedrate 6000 # Z jogging feedrate in mm/min
panel.hotend_temperature 185 # Temp to set hotend when preheat is selected
panel.bed_temperature 60 # Temp to set bed when preheat is selected
## Custom menus : Example of a custom menu entry, which will show up in the Custom entry.
- NOTE _ gets converted to space in the menu and commands, | is used to separate multiple commands
custom_menu.power_on.enable true #
custom_menu.power_on.name Power_on #
custom_menu.power_on.command M80 #
custom_menu.power_off.enable true #
custom_menu.power_off.name Power_off #
custom_menu.power_off.command M81 #
- RE-ARM specific settings do not change
currentcontrol_module_enable false #
digipot_max_current 2.4 # max current
digipot_factor 106.0 # factor for converting current to digipot value
leds_disable true # disable using leds after config loaded
- network settings
network.enable false # true # enable the ethernet network services
#network.webserver.enable true # enable the webserver
#network.telnet.enable true # enable the telnet server
#network.plan9.enable true # enable the plan9 network filesystem
#network.ip_address 10.0.1.100 # the IP address
#network.ip_mask 255.255.255.0 # the ip mask
#network.ip_gateway 10.0.1.60 # the gateway address
#network.mac_override xx.xx.xx.xx.xx.xx # Override the mac address, only do this if you have a conflict
## System configuration
- Serial communications configuration ( baud rate defaults to 9600 if undefined )
- For communication over the UART port, *not* the USB/Serial port
uart0.baud_rate 115200 # Baud rate for the default hardware ( UART ) serial port
second_usb_serial_enable false # This enables a second USB serial port
#leds_disable true # Disable using leds after config loaded
#play_led_disable true # Disable the play led
- Kill button maybe assigned to a different pin, set to the onboard pin by default
kill_button_enable true # Set to true to enable a kill button
kill_button_pin 2.12 # Kill button pin. default is same as pause button 2.12 (2.11 is another good choice)
#msd_disable false # Disable the MSD (USB SDCARD),
#dfu_enable false # For linux developers, set to true to enable DFU
- Only needed on a smoothieboard
currentcontrol_module_enable true # Control stepper motor current via the configuration file
Imported from wikidot
