Photo for my previous post. Abs intra-layer adhesion.
looks like the temperature is too low. Try to print with a higher temperature and a bit more material.
Black is one of the worst colors to print in ABS. The adhesion is very bad because of the color pigments that are used. (mostly carbon black / russ)
Yes listen tothe othr comment. I did the same mistake as you but then I fixed it
