Peter van der Walt could you add some drag&drop layer positioning in LW3?
+Peter van der Walt could you add some drag&drop layer positioning in LW3? Or at least some “move object” buttons? Maybe I’m too ignorant but I haven’t found an easy way to design and engrave and cut some object. Say a panel for the K40 with GLCD display. I design as vector in Autocad/Sketchup/Corel. I have text which I want to engrave and lines which I want to cut. I export the lines as vector and import in LW3 then I export text separately as raster and import but have a hard time aligning them. Or let’s say I have a swisscheese board with some material still left, how can I place the object in that space without fiddling with the XY pos coordinates?
How does lw3 handle hatches or dxf text?
