PCB using ChiliPeppr - Eagle BRD Import - AutoLevel - GRBL - Shapeoko 2
PCB using ChiliPeppr - Eagle BRD Import - AutoLevel - GRBL - Shapeoko 2 Own Electronics.
Gorgeous work.
That looks etched, awesome job. What is the width and clearance of/ between the traces?
The IC is an ATMEGA328-AU, Width: 0.4mm clearence 0.23mm.
Awesome Job! But you are sure you create the gcode with the eagle import widget? On the pcb photo i see some gcode paths they are very big ~1-2mm, as far as i remember the eagle widget can just mill one path, or john update this widget? The generated gcode IMHO from pcb-gcode from eagle or?
https://github.com/lcbulek/Eagle/blob/master/pcb-gcode-3.6.0.4/docs/pcbgcode.pdf
You’re right. Is my mistake. I don’t remember that I used the pcb-gcode plug in. Thanks.
Do you guys need the Eagle BRD widget to generate additional paths to go wider? I have found that this is unnecessary for my boards and adds a lot of time to the milling operation. If you use a good end mill, i.e. not a v-tip, you don’t really need additional paths. However, it is an interesting idea if people really find them important.
