Alright, I am stuck. While cutting a circle near the bottom of the pocket I get a skip and my alignment is off afterword’s. What doesn’t make sense is that it has already cut down 1.2" perfectly. I skips roughly the same place every time. There is no wood to cut where the skip occurs, it was cut away after the first skip. I have looked through the gcode with notepad and camotics and didn’t find anything unusual.
Used:
- Material soft pine
- 6mm x 25mm end mill
- Cambam
- bCNC gCode sender
- Started rough cut @ 10"/min @9000RPM and was working until 1.2" deep
- changed to 5"/min 12000RPM -
Could not find how to post a video here. SMW3D FB
