Over the Pocket Nametags
Hello, I am new to this and hoping someone can point me in the right direction as I have spent hours scouring the internet and no luck thus far.
I want to make over the pocket nametags using the 2 color sheets. I found everything but 1 item. I want to have the aluminum channel that you can slide interchangeable slides in for different offices held. Can anyone tell me where I might find this item?
How big are these things? How are they going to be secured to the pocket? How big are the slide in parts made from the 2-color sheets?
I think more information would be helpful.
This probably isn’t what you are describing but It sounds like it. They are steel and magnets.
Amazon.com : Gersoniel 12 Pieces Magnetic Name Tags Kit Acrylic Name Badge Holders Clear Label Holders with Blank Printable Paper Inserts Magnets Custom Identity for Office : Office Products
I apologize, I should have posted pics for better clarification
In the woodworking world at least, that stuff is called T track or T slot extrusion. It’s used for clamping and all sorts of stuff. I put it on my cnc routers. This place probably has the size you are looking for. Single Slot Sign Holders | Seton
That is perfect. Thank you!
