Originally shared by Scorch Works
K40 Whisperer V0.20 is now available.
http://www.scorchworks.com/K40whisperer/k40whisperer.html…
Highlights of the fixes/ new features:
- Fixed bug that resulted in 45 degree angles being cut too fast
- Added keyboard shortcuts for some main window functions
- Fixed divide by zero error when running g-code
- Added support for hidden layers in DXF files
- Improved interpretation of some DXF files
- Added ability to save and run EGV files. Can run EGV files made by LaserDRW and generate files that can be run from LaserDRW.
- Changed behavior after number of timeouts is exceeded.
- Added logic to wait for the laser to finish running a job before the interface becomes active again.
