Originally shared by Sandy “Skumdog” Lloyd
OK guys here is what I have for sale. If anyone wants this stuff or if you want pics of it let me know. I am letting it all go for $230 + shipping.
2 Bluetooth modules Amp’ed RF BT33
1 micro servo
2 standard size servos
2 150:1 Pololu Micro Metal Gearmotor HP
1 Pololu 30T Track set
4 speaker terminals
4 micro switches w/roller arms
4 tiny 2 position switches
1 safety spst toggle
1 dpst toggle
1 dpdt toggle
1 fuse holder w/ several fuses
2 Ping))) sensors
1 Sharp IR distance sensor 2Y0A21
5 5watt 1ohm resistors
4 dual screw terminals
4 Turnigy X160 plugs
68 high quality electrolytic capacitors 0.47uf(9), 1uf(9), 2.2uf(8), 10uf(10),22uf(10), 47uf(10), 100uf(9), 220uf(1@35v), 470uf(1@35v)
10 1N4001 diodes
10 1N4002 diodes
1 large collection of resistors.
7 2N2222A transistors
7 2N3904 transistors
7 2N4401 transistors
DS1820 high precision one wire temp sensor
10 L4391 very low dropout voltage regulator
6 LM335 temp sensors
1 Zumo chassis kit (no motor)
4 momentary buttons
2 red Multimeter probe jacks
2 black multimeter probe jacks
1 micro metal gearmotor bracket extended pair
6 DC line in jacks 5.5mm x 21mm
2 5mm LED housing
2 3mm LED housing
22 IR LED’s
22 IR LED sensors
15 RGB LEDs
12 SMD RGB LEDs
2 MX2125 dual axis accelerometer
1 L3G4200D triple axis gyro
1 hall effect sensor
1 radio shack camera shield
1 2.8" TFT touch shield seemed studio’s
1 arduino mega
1 arduino uno
1 Turnigy lithium polymer battery charger
1 7.3v Turnigy lithium polymer battery
Multiple LEDs of varying colors.
Plus storage boxes of all types, and an assortment of IC’s
