Originally shared by Sam De La Haye
Slight change of plans, rather than bolting the legs for the gantry on the sides, I’ve changed it so they bolt on from the top. The aim is that when the base is taken to be machined its all on the same plane, also got most of the 12mm bar welded on which will be skimmed.
