Originally shared by Josh Azevedo Clear abs with smoothing.
gplus
(Thomas Sanladerer) #1
Clear abs with smoothing. Someone asked about clear and and smoothing. I had this guy laying around that was my first print in abs. Failed on the top had a small hole. Vapor smoothed about 30/40 seconds.
(Don Tuininga) #2
Those look fantastic!
(Louise Driggers) #3
That’s worth investigating. Thanks for posting this.
(Tim Sills) #4
I hadn’t seen clear prints before, they’re surprisingly…clear.
(Stephen Baird) #5
I can’t comment on the original post, unfortunately, so I may never get an answer… But what sort of clear ABS is this? I looked into it once upon a time, and there are a few standard formulations for it that aren’t quite just ABS, but I never got to the point of playing with the different options to see which would give the best transparency effects.
(Thomas Sanladerer) #6
Tagging @Josh_Azevedo
(Peter L) #7
I will try this today, I have some failed clear abs part to test on.
Looks good.
(Jon Caywood) #8
Top secret clear ABS or something currently available?
(ThantiK) #9
@Jon_Caywood , it’s available out there. I was introduced to the stuff as “MABS” by @Whosa_whatsis a while back. Just google “Clear ABS”. It’s not typically listed as MABS anywhere.
(Chris Lane) #10
Makes me wonder if decent glass lenses could be printed using that material (I’m no expert on refraction, etc. though)
