Originally shared by Jeff Keegan
I think one of the LM8UU bearings on my Prusa i2 went bad (at least that’s my best guess). The X axis has extreme trouble moving to the right (it stutters and skips), but it can usually move left fine. If I spray it that morning with silicon lube, it’ll sort of work for a while (but I think that’s just lubricated metal rubbing against metal on a broken bearing). The smooth rods have long sharp scratches in them now. Grrr. Because of the style of the i2 ends, the rods are trapped so I can’t replace them without basically removing the entire Z axis to get at the X axis. Maybe I’ll go with printed PLA bushings instead… Anyone have this happen?
