Originally shared by Greg Nutt
For fans of the E3D Titan Aero on a Prusa I3, here is a remix of the E3D fan mount that includes a mount for the BLTouch that I’ve made. It might work for the Titan/v6 combo too, but I haven’t tested it yet.
Your Thingiverse page for this design is very sparse. You should include information on what fan this is intended to be used with as well as mounting information.
It is remixed from the E3D model. See the original model.
Okay so you just added the tab for mounting the BLTouch. Make sure you adjust your X/Y probe offset if you’re doing multi-point probing since this mounts the probe a considerable distance from the nozzle.
